Author Topic: RS485 PWM controller  (Read 4788 times)
Offline richcj10Topic starter
« on: January 28, 2013, 12:18:33 am »
I am using a ATmega328P uC with a TLC5940 (Used in a PWM Mode w/ pullups).
I use a MAX485 chip to receive the serial commands.  It works well with most motor controllers and all servos.
The one motor controller it doesn't work is the Vector Motor Controllers. I can't figure out why they don't like the signal(They think that the signal isn't there).  Attached is the schematic of the system. Any suggestions would be great!
Thanks,
Rick
« Last Edit: January 28, 2013, 12:29:20 am by richcj10 »
Offline Kremmen
Re: RS485 PWM controller
« Reply #1 on: January 28, 2013, 06:55:59 am »
Be more specific, please. What serial commands? Which protocol? What vector controllers? What commands?
Nothing sings like a kilovolt.
Dr W. Bishop
« Reply #2 on: January 28, 2013, 07:24:34 am »
The board receives speed commands via a serial stream over RS485. The board sends out commands to the motor controllers via PWM.
This device (ATmega328P) handles logarithmic ramping / updating / and safety shutoff.
The motor controllers in question are the IFI VEX Pro Victor 88x.  I like these because of there rigidity for there price points.
But the draw back is they are very sensitive to the signal coming into them. They like to go into a fault condition representing a bad or no signal.
I have gotten them to work with a output Compare peripheral on a AVR.
Online amyk
« Reply #3 on: January 28, 2013, 08:48:10 am »
How about some scope/LA screenshots? Have you tried inspecting the signals?
