Hello All,
I am working on a GPS project that uses a CAM-M8 Ublox module.The back of the board has two clips for attaching a AA LifePo4 battery to supply unregulated power to the boards components. To this end, the board was going to be 15x61 mm - the minimum size required to clip onto the AA battery and still accommodate my wider components.
However, according to the hardware integration manual
https://www.u-blox.com/en/docs/UBX-15030063 (page 15, section 2.6) for the GNS receiver, I have to:
1) Ensure a minimum ground plane of 20x45 mm
2) Keep 6mm of clearance around the receiver module
3) Keep the receiver at least 10mm from the corners of the board
Ugh fine, so I made the board shorter & wider, and I am now using 14430 LiFePo4 so I can trim the length.
So my question now is, if I have the battery mounted directly underneath the GNS receiver (as shown in the pictures), how much of a problem am I making for myself?
According to the data sheet ‘
Note that the embedded GNSS atenna requires a small ground plane clearance and a void read (4.8 x 7.2 mm) for copper plane and trace for all layers under the antenna. Placement of other components is not allowed under the keep-out area on the opposite side.’ Ok, so I've added the keep out zone to board (shown in orange on the PCB layout, and white on the bottom silkscreen of the 3D view)
Is this layout really going to hurt performance? I really don’t have much experience with this and don’t know how to quantify the effect on performance. Perhaps somebody can shed some light on the matter. According to the data sheet, by going this small I have already cut the receiver strength by 6dB ‘
A 45-mm wide application board reduces the signal levels by at least 6 dB compared to full 80x40 mm ground plane’
The device is designed to be used on the water, so it should always have a clear view of the sky. However, I don’t want to reduce performance if I don’t have too…
Cheers!
Brett
