Quote from: DanielRehak on August 27, 2024, 04:05:43 pmQuote from: mikeselectricstuff on August 27, 2024, 03:55:51 pmCould you stretch the grommet over a USB-C plug? Maybe with the plastic overmoulding stripped off?This can be done but you risk stretching the grommet so much it will no longer seal properly. You would need to find a grommet that fulfills following:1) maximum cable diameter that can fit inside grommet >= maximum USB connector width2) minimum cable diameter that can fit inside grommet <= USB cable diameterAnd there does not exist anything like that. Max specced dia when used in the gland isn't the same as what you can stretch it to when taken out of the gland.
Quote from: voltsandjolts on August 28, 2024, 04:10:05 pmhttps://www.lindy.co.uk/usb-c4/200m-fibre-optic-usb-3-0-extender-p9144...and othersThis looks interesting. It is definitely the smallest one i ever saw. But its pretty expensive and mainly it needs 5V 3A power supply which could be solved but would be high effort.
This company make 2 part cable glands that are Ex certified: https://www.roxtec.com/us/our-products/solutions/?filters=49193We use the non Ex version often at work, nice quality products.
Is it an option to replace such glands with some kind of polymerizing caulk? (Silicone or polymer based)1. Put the cable though.2. Fill the hole with caulk3. Let it dry.4. Mount the nut to put some pressure on the caulk so it seals.I guess you have to deal with all kinds of regulations when you have to design for an explosion proof environment.
I would probably cut of the plug, feed the cable through, and then use some non standard connector or soldering inside the box.But there are also USB connectors made for manual assembly as the picture shown by quadchannel. I had to frown my eyebrow for a moment to see how it works, but the plastic insert is shown rotated 180 degrees. The tin plated tabs is where you solder on the wires inside the plug.Maybe it is an option to cut of the plug on the other side and then feed through the whole cable?
