Wow, you guys aren't kidding, that is some errata.
What are the alternatives for a PDIP8 i2c RTC? DS1307 ? Anything else?
This is for a hobbiest type project where it isn't critical, so it may still be workable.
Issue #1 can be avoided if you follow what the datasheet says and don't try to change the time with the oscillator started.
Issue #2 can be avoided by not using either the trim feature or the alarm feature.
Issue #3/4 can be avoided by only setting the time when stopped and then rereading back the registers to make sure they were written correctly before starting the time. If they were not rewrite them. Only an issue when setting the time, or when trying to clear the PWRFAIL bit. I question the lack of wisdom in making bits like PWRFAIL part of the weekday so you can't clear them without rewriting a field that might change (weekday) if the time is running.
If I use the DS1307 instead, it lacks trim all together so issue #2 is a non issue because if you don't use it no problem. It also lacks the alarm or pwrfail stamping, so again, if you stop the time like the datasheet says, set it, read it to make sure it set properly, then start it, I'm not sure the DS1307 has as much to offer for 4 times the price.
The PWRFAIL is the one that annoys me though. Issue #4 could occur if you write it (to clear pwrfail) while the oscillator is running. The problem with writing it when the oscillator is running is that you could be on the edge of it changing and writng the wrong value (yesterday). You don't want to stop/start the clock every time you turn the unit on and PWRFAIL is set either because it would eventually lose time. I suppose the only thing to do is read the time, make sure you aren't in the window of a day rollover (such as within 2s of it) and update it while running. If within 2s, then delay until it rolls over, then change it. The 2s could be much shorter, maybe just 1s, just look for a time of 23:59:59 and delay 1s if found. They should have put this flag somewhere else if it has to be commonly cleared!
What do yo guys think about the layout in my previous message? I tend to avoid crystals because I don't like how careful you have to be when laying them out.
