Author Topic: Generic keyboard/keypad keys?  (Read 5397 times)
Offline Andrew_KTopic starter
    • Personal Blog
« on: September 20, 2016, 10:24:35 pm »
Hey all,
I'm looking to incorporate keyboard keys into a few embedded projects of mine, but I'm trying to avoid using Cherry MX switches as they are pricey.
I know they have to exist somewhere, but I can't seem to find any to buy online. I'm looking for something like this https://sli.mg/a/gV0pVJ. I've seen these keys used in other embedded projects, for example that camera controller, CNC controllers, or cash registers.
I find it hard to believe that a generic variant of these do not exist... All I have been able to find when searching Dome/Membrane/Silicone/Keypad/Switches/etc. were tactile switches/domes or those cheap Chinese membrane stickers like this http://www.vetco.net/catalog/images/VUPN6955-1.jpg
To be clear, I am not looking for those cheap Chinese keypads, but rather a solution that looks like a standard keyboard. Ideally it would come with keys, membrane pad, and key retainers, and would make contact directly with the PCB.
If it turns out I can't find any from china, I'll probably just make my own molds and mill them myself. While this works (I've done some initial tests with resin and silicone casting), it's a pain in the ass to do, takes hours to machine, and I'd rather buy something pre-made. I thought I would check the internet one more time before committing hours to this.
Thanks,
Andrew
« Last Edit: September 20, 2016, 11:38:26 pm by Andrew_K »
    • Personal Blog
Re: Generic keyboard/keypad keys?
« Reply #1 on: September 20, 2016, 11:42:47 pm »
 The cheapest I was finding was about $.80 a cherry switch without key caps. Are they cheaper somewhere else?
Online ataradov
    • Personal site
« Reply #2 on: September 21, 2016, 01:46:35 am »
There are push buttons like this http://www.ebay.com/itm/5-Pcs-Momentary-Tact-Tactile-Push-Button-Switch-12-x-12mm-x-10mm-4-Pin-DIP-w-Cap-/271497055911?hash=item3f367c4ea7:g:Pg0AAOSw3v5XItz1 all over eBay. This specific one is just a random one, there are way better prices out there. Caps can be sold separately and they are available in a variety of colors (all with transparent cap).
They are probably not as reliable as regular keyboard keys, but that is ok in many cases.
Alex
    • Personal Blog
« Reply #3 on: September 21, 2016, 03:49:12 am »
Unfortunately my idea needs physical keyboard keys, like a computer would have. It's purely aesthetic, but it wouldn't sell if it used a cheap rubber button pad. Actually, this is for a prototype human interface device for computers... so that's why I'm being so picky. I want the final product to be nice.
And I did find some cheaper Chinese version of the cherry MX keys. $0.30 per switch is a lot more reasonable than $0.85 on digikey or ebay. Still, I'd like to cut the cost as much as possible. It's likely this won't be as big a success as I want it to be, but just in case, I'm designing it with manufacturing in mind. This is a device that will need 20+ keys, and half the cost is already on the key switches. Not including PCB, which is why the standalone membranes are so appealing.
I know they've manufactured them for other products... And they HAVE to exist generically somewhere... Just look at this picture I found: http://image.ec21.com/image/posprinterparts/oimg_GC06470592_CA06991740/Sell_Wincor_TA61_Keyboard_Silicone_Membrane.jpg. It's arranged in a square grid rather than a QWERTY layout, which tells me these are cut in to strips and used for smaller embedded applications.
Online ataradov
    • Personal site
« Reply #4 on: September 21, 2016, 03:53:36 am »
Then your problem solved. If product does not sell well, then keys will be a bit more expensive, otherwise, they are $0.47 @ 5000 pcs on Digikey.
Alex
Offline dom0
« Reply #5 on: September 21, 2016, 05:44:42 pm »
Almost all of these feel awful.
Cherry MX switches are imho the way to go here. There are companies that can print you keycaps with any labelling you desire for a reasonable price (e.g. wasdkeyboards), today you could probably even get away with 3D-printing your key caps.
Offline ebclr
« Reply #6 on: September 21, 2016, 05:51:11 pm »
