Author Topic: Name of Mitutoyo pcb connector???  (Read 2198 times)
Offline MDM3DTopic starter
« on: November 24, 2016, 04:23:24 pm »
Does any one have any idea what type of connector is used to connect to a Mitutoyo digital indicator?  The connections appears to be just exposed pads that are connected by spring pins like in this cable.
http://ecatalog.mitutoyo.com/SPC-Connecting-Cables-C1643.aspx
 I would really like to not have to pay $40 for a tiny connector. I can post dimensions if they are needed.
Thanks
UNIVERSAL LAW 1, EVERYTHING runs on Smoke... If the smoke is released then it no longer functions.
--- Source: Unknown
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Name of Mitutoyo pcb connector???
« Reply #1 on: November 25, 2016, 09:58:01 am »
Almost certainly custom
Day Job: Mostly LEDs
Offline jonwhite
« Reply #2 on: November 25, 2016, 10:26:16 am »
Hi mike
Love your vids please keep making them  thank you
Offline jpanhalt
« Reply #3 on: November 25, 2016, 10:32:56 am »
I did a project with the Mitutoyo dial indicator and ended up buying the control cable from Mitutoyo.
John
Offline Zom-B
« Reply #4 on: November 25, 2016, 01:25:09 pm »
Lol, I thought it says on the back "ABS Lute". What the hell is a 'Lute'? Ooh.. i c, AbsOlute!
Offline ajb
« Reply #5 on: November 25, 2016, 09:46:23 pm »
You can get SMT spring contact fingers, depending on the pitch a small PCB with a few if those might make a serviceable connector.  But for a one off, may not be worth the hassle to save $40.
« Reply #6 on: November 25, 2016, 09:49:10 pm »
OK would they actually be called that on a place like digikey or mouser or is there some trade name I'm missing like how dupont connoctors are .1 inch pin headers?
Sent from my SAMSUNG-SM-G900A using Tapatalk
--- Source: Unknown
Offline owiecc
    • Google scholar profile
« Reply #7 on: November 26, 2016, 01:04:30 pm »
Just solder a pin header there. The pitch seems reasonable, maybe .1 header will fit.
Offline ajb
« Reply #8 on: November 26, 2016, 06:38:03 pm »
http://www.digikey.com/product-search/en/connectors-interconnects/contacts-spring-loaded-and-pressure/
You may also find similar things categorized with EMI components, since such spring contacts are often used to make contact with shields integrated into mechanical housings.
The following users thanked this post: MDM3D
« Reply #9 on: November 27, 2016, 02:27:36 am »
The pitch appears to be 1.5mm so the easy solution of pin headers will not suffice and I do not want to solder to the $500 indicator board. The emi connectors look promising Ill see where that takes me. thanks for your help.
--- Source: Unknown
