I am building a test switcher with the wrong IC - it is just one I happen to have. A UC3842 which stops working when the input voltage gets down to 10V. It will be enough to get the measurements I need. The reason I need to do testing is that a 3 to 20V input, and a 3 to 27 volts output is a huge range if I want to get a full 1A out for every input/output combinations. I may have to cut the input range back to 10V to 20V. That range means old PC supplies could be used as a power source.
3V input would allow a single Lithium battery to be used, but to get 1A out at 25V, a 3V lithium cell would be outputting about 13A. For people who wanted to make a small 200mA supply, currents of up to 2.5 A peak from the cell sound a lot better.
To get the full range of input and output, I am using a flyback design. I want to get it working to test out the transformer and the secondary circuit. With the peak current that is the result of the big voltage range, I probably have to use a controller with an external power MOSFET, but I am not going to choose a regulator until I have a good feel for the frequency I need and I have worked out the transformer details. It is a spare time job, but I might get a few days to work on it this week, which will be good.
Once I know where I am going with the switching pre-regulator, I will put together something summarizing all the ideas, but to give a preview, the main reason I want the boards to be fully isolated from the power source is that I am designing the 25V 1A supply boards so they can run in parallel or serial in a master-slave configuration. So if you want a 25v 5A supply, just put 5 boards in parallel. If you want 100V 1A supply, put 4 boards in series. Or if you want a 100V 5A supply, then I know you are crazy - but why not? It is only 20 boards.
What I discovered is it is probably impossible to come up with a general purpose design for a single regulator that could be scaled from a 100mA supply to a 10A supply without a redesign. But I can make a single fixed size board that is highly versatile and configurable.
I am borrowing the series/paralleling idea from the old HP supplies, but it is one of those ideas I will have to test for real. No reason why it shouldn't work though.
If you are building a bigger supply, you could use a PC power supply as a source. One of the compact-sized PC supplies (200W - 350W) is still pretty compact,
It may sound odd, but the thing is if each board is very cheap, it will probably end up being a much cheaper and quicker way to get a supply going then trying to custom design a dedicated supply. It is quite possible that the BOM of the parts for a board excluding the PCB will be under $10. All the parts are easily available through hole, so it is possible to have a through-hole kit - not that I have any real plans at this stage.
It is possible that I can get the board over 1A, but the first rev will be 1A to be conservative. Don't think I want to go above 25Volts. 30V is technically possible, but it is getting too close to the opamp limits for my liking.
There will also be an option of a linear pre-regulator with a heatsink, so you can put the board in a box with with a transformer.
Richard.
