Hi all,
just out of curiosity I did a teardown of a low-cost game console (15€, "Tchibo Retro-Mini-Spielekonsole").
Most parts were no suprise. Unfortunately I wasn´t able to identify the controller.
But one thing really puzzeld me: It seems that there is a kind of security chip on the board. Why the hell would a 15€-console need a security chip?
Perhaps some experts can give me a hint:
- What kind of controller works in this console?
- What might the unknown chip do?
- What kind of chip might the unkown chip be?
And now pictures:
The upper SO-8 is a 25Q32 4MB-Flash.
The blob in the middle contains the controller.
The lower SO-8 is the interesting chip. Supply, ground and three "logic lines".
The mystery chip.
Backside of the mystery chip.
So what´s happening here?
After startup the controller fetches 8kB from the flash.
1,3s later the mystery chip is adressed for the first time.
Then there is a lot of data between flash and controller.
Every 95ms (in the menu) or 63ms (in a game) the Controller talks to the mystery chip. Every time only one short "hello".
Clock for the flash is 16MHz. Clock to the mystery chip seems to be 33kHz.
First communication contains "two impulses", all the other communications contain only "one impulse" always at the same location.
Without the chip the game is dead.
Controller-Die
B1056
The mystery-chip-die.
And here everything on my hompage (in german):
https://www.richis-lab.de/tcm_rg.htmAny ideas?
Greetings,
Richard
