Author Topic: mini USB or micro USB for new product  (Read 6202 times)
Offline atwozTopic starter
« on: June 17, 2012, 01:28:50 pm »
Hello,
I'm designing a product that will have USB connection that will rarely be used since it's just for configuration (probably around 30 uses Max in its life time).
I have enough room to put a mini USB with no problem.
I read that the mini USB has been deprecated by the USB Org.
I like the mini USB because its easier to see the orientation of the connector and because it's easier to hand solder.
What do you guys think, should I use mini USB or micro USB for this new project.
Thanks for sharing your opinion!
Offline 8086
    • Circuitology - Electronics Assembly
Re: mini USB or micro USB for new product
« Reply #1 on: June 17, 2012, 01:31:08 pm »
Always micro USB on new designs.
Offline Short Circuit
« Reply #2 on: June 17, 2012, 01:46:38 pm »
Do whatever you preffer. Mini USB is still used alot, so cables will be readily available for quite some time.
Also, mini USB connectors have more 'body', allowing for ~2mm protruding through the wall or frontpanel of a housing. Standard Micro USB sockets are less suitable for that.
btw According the wikipedia article, Mini USB B is not deprecated, only the Mini USB A variant (for USB Host/OTG).
« Last Edit: June 17, 2012, 01:53:59 pm by Short Circuit »
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: June 17, 2012, 02:13:40 pm »
Mini USB only lasts for 1,500 USB 5,000 µUSB 10,000
Offline hlavac
  • Country: cz
« Reply #4 on: June 17, 2012, 02:46:28 pm »
Haha Big USB B for me any time... just for the mechanical meatiness :) I hate these sneeze-to-break miniature versions...
Good enough is the enemy of the best.
Offline firewalker
  • Country: gr
« Reply #5 on: June 17, 2012, 02:49:21 pm »
I believe that standard USB is for 1500 cycles an mini for 5000.
Alexander.
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: June 17, 2012, 03:02:34 pm »
Alexander.
Read up wiki, it's the other way round mini is the worst of the lot
Mechanically the µUSB is the toughest
Offline firewalker
  • Country: gr
« Reply #7 on: June 17, 2012, 03:10:57 pm »
Wikipedia states:
The newer Micro-USB receptacles are designed for up to 10,000 cycles of insertion and removal between the receptacle and plug, compared to 1,500 for the standard USB and 5,000 for the Mini-USB receptacle.
Alexander.
Offline 8086
« Reply #8 on: June 17, 2012, 04:47:24 pm »
Makes sense, since the standard usb connector is for larger eqiupment and will usually be plugged/unplugged less often than the smaller connectors often found on portable devices
Offline codeboy2k
« Reply #9 on: June 18, 2012, 06:43:35 am »
Micro-USB can have more insertion cycles, but they are not the toughest (i.e. strongest) usb connector.  The micro-usb is still more fragile, and will break internally or tear off the board with forces applied to the protuding lead.  It will do this much more easily than the larger connectors.
It does have a longer insertion lifetime, however, if it will last that long on your product.
« Reply #10 on: June 21, 2012, 01:55:53 am »
Thanks a lot for the replies. I think I will go for mini-usb type B.
Offline T4P
  • Country: sg
    • T4P
« Reply #11 on: June 21, 2012, 02:24:09 am »
NO! It's not going to last at ALL!
Seriously if you think you want mini B go micro B really
I have seen mini B break off faster then micro B many times
« Reply #12 on: June 23, 2012, 01:23:21 pm »
Oh, thanks for the info! However the USB will only be used from 5 to 40 times on each product. It's just for configuration purposes. What do you think?
Offline T4P
  • Country: sg
    • T4P
« Reply #13 on: June 23, 2012, 01:59:29 pm »
In that case, as big as you can get will be much better
