Author Topic: Help Wanted! Pinout/Manual Of VAKO DISPALYS CL501/CS CRT Modual  (Read 316 times)
Offline TheEPROM9Topic starter
  • I have a Kali USB and I'm not afraid to use it!
    • EPROM 9 Home
« on: October 05, 2019, 07:24:35 pm »
I have a VAKO DISPALYS CL501/CS CRT Display Modual. It is a really neat greenscreen display that I want to use for a retro computer project. However I have had 0% luck with this, I have however found the 12V power input & when I power it up the HV works as you can hear the 15KHz. However there is no raster on the display or any other sign of life.
I have tryed to find documentation on line but I have currently found nothing. I don't know if anyone has tips & tricks or has worked with these at some point as it is from 1988, or can help me reverce engineer it as I am not to familour with the nitty grity detailes CRT circitry.
Only IC Is UPC1031H2 Vertical Deflection Driver. The rest of the active comonets are transistors.
I have attached sevrail images to provide at least some context.
TheEPROM9 (The Husky Hunter Collectors inc.)
Knowledge should be sheared freely to those who want it.
https://www.flickr.com/photos/146977913@N06/ https://www.youtube.com/channel/UC4vOnjz1G-aM8LddSbrK1Vg https://www.facebook.com/groups/118910608126229/
