Author Topic: Frequency measurement  (Read 800 times)
Offline namsterTopic starter
  • Country: dz
« on: November 21, 2019, 11:19:39 am »
Hi ,
what are the techniques for a precision frequency measurement ? , the DATA can be used but i don't think that give a good precision !
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
Re: Frequency measurement
« Reply #1 on: November 21, 2019, 12:30:43 pm »
Precision measurement can be performed using a frequency counter with an accurate time base. There are frequency counters out there which could do the job. Basically you set the counter start and stop using the 1 sec precision pulse and clock it with the input signal.
for low frequencies, use a PLL to scale up the frequency before measurement. This gives better precision.
Making products for IOT
Offline FenTiger
« Reply #2 on: November 21, 2019, 12:42:11 pm »
This article describes a couple of techniques: http://n1.taur.dk/permanent/frequencymeasurement.pdf
  • Country: dz
« Reply #3 on: November 23, 2019, 08:50:48 am »
thanks for the orientation , I will do some research
