update:
the FMD IDE and ORIGIN IDE are basically the same. you can burn and load HEX files produced by both IDES to both chips.
if you look at the datasheets of MS8x and FMD you'll see that they're basically the same, (on page 8 of the MS81x series datasheet you'll see that Origin even forgot to change some FMD register names! )
however the unlike the PICs it's not possible to put "#pragma config xxx" and it seems that the IDE doesn't let you config them by code and it put's it's own special coding in the HEX file. hence there's some kind of obfuscation involved. if you see the HEX file produced by the IDE and you look at the one before the last line you'll see the config options there. as opposed to what says in the datasheet, the config is written starting at address 0x4000 (instead of 0x2000), and I think the programmer will detect that and apply the correct address when programming.
I wanted to test the features the config options provide, and to my surprise, the EEPROM section has no protection and there's no config to protect it. since these chips are clones of the PICs, I thought the manufacturer might be hiding some features but looking at the fusebits of PICs, I noticed that the UCFG0 mapping is different. however, some bitfields are left as preserved while they could actually do something that's not stated in the datasheet, (like the case in padauk MCUs). Chinese datasheets are very horrible and usually, there are always some parts left out and not explained.
long story short, to test the preserved bits in the config (UCFGx) section, the HEX file must be edited manually but it's not a straightforward process and it seems some additional work is required.
in case anyone's interested here is my finding on the cryptic config options that the IDE produces.
in the HEX file you'll see something like this. on the one before the last line which is the standard intel HEX format.
| len | addr | type | data | checksum |
| 0D | 4000 | 00 | D4 03 E0 09 F6 05 FF 0D0102000108 | E0 |
the data part changes according to the options you select in the IDE, this option also includes the ones in the project -> properties menu like number of programming , etc. the bytes are scattered like this:
| UCFG0 | UNK0 | UCFG1 | UNK1 | UCFG2 | UNK2 | rest of data |
| D4 | 03 | E0 | 09 | F6 | 05 | FF 0D0102000108 |
I could only observe that the UCFG0-2 positions like the table above and the other parts remain unknown and also if the UCFG0 part changes some other part may change as well so it's not possible to manually modify the UCFG's and try out different options because the programmer will detect this as error (not tested).
the UNK0 and UNK1 seem to remain constant on all mixture of configurations but UNK2 changes. also the UNK values differ in each MS8x or FT6x series. the above table is for MS81 series.
if anyone has any clue I'm interested to try things out.
