Author Topic: Tracking down a Datasheet: Omron g4d-287p-bt2 5V  (Read 3677 times)
Offline jigglesTopic starter
« on: January 12, 2014, 05:04:36 am »
Can anyone point me in the right direction or even just some info on a relay I have found? Its a Omron g4d-287p-bt2 5V. Google comes up with nothing at all! :( Seems a fairly old relay to the point that Omron have nothing about it on their site!
Thanks in advanced!
Offline calexanian
    • Alex-Tronix
Re: Tracking down a Datasheet: Omron g4d-287p-bt2 5V
« Reply #1 on: January 12, 2014, 06:37:15 pm »
http://www.ebay.co.uk/itm/5x-Omron-G4D-287P-BT2-PS-3-6VDC-2-pole-change-over-3-6v-/150596011434
From the picture on the top it looks to be a double pole double throw pretty standard relay. It has been discontinued. There is the pinout so it should not be hard to find something close enough to bodge in.
Charles Alexanian
Alex-Tronix Control Systems
« Reply #2 on: January 12, 2014, 07:54:37 pm »
I know the pin out I was just wanting to know the current draw of the coil and such.
Offline calexanian
    • Alex-Tronix
« Reply #3 on: January 13, 2014, 12:16:48 am »
g4d series I believe were 5 amp contact depending of the plating type. But its been a few years (15) since I have looked at those. We use Hasco KSD series relays. Relays kinda fall into standard pinout/package/current categories so the Chinese may copy them easier!
Charles Alexanian
