Author Topic: YABSa: Yet another bench Supply (version A)  (Read 4614 times)
Offline JebnorTopic starter
  • Absolutely! Yes, kind of, sort of, not really, no.
« on: October 05, 2013, 05:41:31 am »
I've been working on my new bench supply. I've successfully created a positive supply which has <5mVpp Noise at 12V, over a current range from 0 to 1.2A.
I use no ICs.  Thought anyone? Is there anything I'm missing?
« Last Edit: October 05, 2013, 05:44:13 am by Jebnor »
Before this, there was a typo.
Offline BravoV
  • +++ ATH1
Re: YABSa: Yet another bench Supply (version A)
« Reply #1 on: October 05, 2013, 06:28:44 am »
Not an expert, just a thought, since that D6 1N4148 diode is series with the zener forming the voltage reference, that D6 tempco is about -2.1 mV per celcius, isn't that will affect the output stability ? cmiiw
« Reply #2 on: October 05, 2013, 06:47:35 am »
Oh, Probably... Everything else is temperature compensated, as far as I can tell, so why skimp on the most important part.
I have a bunch of the 1N4742a's around, I could select one and adjust the current source so that it is above 12V and then use RV1 to fine tune.
Offline codeboy2k
« Reply #3 on: October 05, 2013, 08:06:46 am »
I thought it was obvious... the zener's reverse biased and thus it's tempco is approx +2mv/C... the diode D6 being forward biased is approx. -2mV/C... the two tempcos cancel each other out and this stabilizes the voltage ref over temperature.
Offline BravoV
  • +++ ATH1
« Reply #4 on: October 05, 2013, 08:10:35 am »
Cool  :-+ , thanks guys.
Offline quantumvolt
  • Country: th
« Reply #5 on: October 05, 2013, 10:55:41 am »
Very nice. I like it all discrete. Matching transistors for current mirrors and diff amps is for the dedicated  ;D
There is more to it. The tempco varies with Zener voltage. So for example to make a decent 9 V temp compensated voltage it is common to use a 7.5 V Zener and 2 small signal PN diodes in series. Here is a decent short read: http://www.techlib.com/reference/zenertempco.htm
« Reply #6 on: October 05, 2013, 02:00:13 pm »
Turns out I may have accidentally did something better.
[cut]
And now, to run down the zener Diode temperature compensation rabbit hole.
Thank you all.
« Reply #7 on: October 05, 2013, 02:17:23 pm »
Probably more than you wanted to know about Zener Diodes (127pg): http://www.onsemi.com/pub_link/Collateral/HBD854-D.PDF
