How to set the flyback converter work in dcm mode i mean how do i choose critical magnetizing inductance so that the converter operates in DCM mode.
I found some equation
Lm critical =(vi * D * D * T)/(2 * Ii)
if Lm>Ltotal its DCM
if Lm<Ltotal its CCM
if Lm=Ltotal its boundary condition
where Vi =input voltage
D = duty ratio
T = total time period
Ii = input primary current
Lm = magnetizing inductance
Ltotal = Total inductance of primary
if above case then if i choose to calculate at minimum input voltage then i need to set maximum duty cycle and total time period in the above equation.
I got confused on these please guide me or provide materials related.
Thank you.
