I picked up this bottle at the local hobby store a little while ago, as you can hopefully see in the photo there's a pin in the lid that slides into the needle when you close it so it always clears the passage. It does make it a little fiddly to close, but it works quite well. I also generally use a low-solids flux that doesn't tend to crust up as much as rosin does, I suspect that helps.
Unfortunately there's no branding on the bottle and I can't seem to find it on the stores website. I'll try to remember to pop in the store next time I'm down that way and check, I wouldn't mind grabbing another for work anyway. I just walked right by that store this afternoon, too!
