Author Topic: White Led strip for a Lightbox(board)  (Read 2222 times)
Offline ArcamaxTopic starter
« on: May 05, 2015, 03:03:59 pm »
Should i use a 5050 warm white or a pure white strip. Cant decide 100% |O
http://www.ebay.ca/itm/371305992754?_trksid=p2055119.m1438.l2649&var=640425017958&ssPageName=STRK%3AMEBIDX%3AIT
I want to use my clear acrylic i have laying around. I'll just scuff it up with course sandpaper to give it an etched effect so it shines/glows nicely.
« Last Edit: May 05, 2015, 03:21:14 pm by Arcamax »
Offline ajb
Re: White Led strip for a Lightbox(board)
« Reply #1 on: May 05, 2015, 05:11:02 pm »
. . .depends on if you want it too be warm white or pure white?  It's really an aesthetic judgement.
Online georges80
« Reply #2 on: May 05, 2015, 05:52:30 pm »
It is a subjective choice.
Warm white is nice for general interior lighting since it is what we're used to coming from incandescent bulbs and candles...
Cold white is 'clinical'...
IMHO.
cheers,
george.
Offline Zero999
  • 0999
« Reply #3 on: May 05, 2015, 06:12:14 pm »
Where is it going to be used?
« Reply #4 on: May 05, 2015, 06:52:22 pm »
im making a light board to trace pictures with
Offline Zero999
  • 0999
« Reply #5 on: May 05, 2015, 07:19:05 pm »
Pure white is probably best then.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #6 on: May 06, 2015, 04:16:29 am »
If you ever expect to use the light box for any colour evaluation - then definitely use the 'pure' white.
The yellow 'warm' white, will challenge your eyes trying to match colours in disparate pieces of content..
Don't ask a question if you aren't willing to listen to the answer.
Online georges80
« Reply #7 on: May 06, 2015, 04:41:19 am »
"pure white" is hardly pure - wrt to LEDs. Check their spectrum... Besides, I have no idea what you would call "pure white".
Basically there's a colour temperature binning for white LEDs and you can choose from a large range. The spectrum is still not broad band (lots of peaks).
You can also use cold white and mix in amber LEDs as needed to shift the colour temperature to what is 'nice' for you.
cheers,
george.
Offline miguelvp
« Reply #8 on: May 06, 2015, 04:55:29 am »
Or you could use the back light of a monitor or a laptop without the LCD but keeping the diffusers.
I don't think it ended up giving a lot of light, but enough for doing the job.
But I bet is cheaper to purchase used X-Ray light boxes or even new ones from ebay.
http://www.ebay.com/sch/i.html?_nkw=xray+light+box
Edit: or even cheaper, tracing light boxes from ebay :)
http://www.ebay.com/sch/i.html?_nkw=tracing+light+box
« Last Edit: May 06, 2015, 04:58:29 am by miguelvp »
