Hi Guys,
I recently spun a board with 3 BGA's (1.0mm pitch 676-pin FPGA + 2x DDR3 SDRAM 0.8mm pitch).
The board just came in and I noticed that I forgot to tent the vias under the BGA's (oops!).
I am considering the following fix before sending it off for assembly:
1. Order a stencil with cutouts in place of the vias to be tented.
2. Apply curable solder mask to the vias only using the stencil.
3. Cure with UV.
Can someone share some advice? Is there a better way?
Thanks!
