Author Topic: Cleaning up toner from board after toner-transfer etching.  (Read 2939 times)
Offline AlanaTopic starter
« on: October 05, 2012, 01:53:00 pm »
What solvents or other methods do you use to remove toner from your PCB after you have etched them using toner-transfer method.
I tried nitro solvent but it does not clean it, just helps to remove toner mechanically.
Offline Psi
Re: Cleaning up toner from board after toner-transfer etching.
« Reply #1 on: October 05, 2012, 01:57:35 pm »
Try turpentine, pretty sure that's what i used last time and the toner dissolved right off.
Online kripton2035
« Reply #2 on: October 05, 2012, 02:38:52 pm »
acetone was working right away for me last week ...
easier to find ?
Offline RCMR
« Reply #3 on: October 05, 2012, 08:53:51 pm »
For the Brother toner I use an aerosol can of brake-kleen -- however I suspect that acetone would work just as well.
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
« Reply #4 on: October 05, 2012, 10:36:05 pm »
acetone FTW or nail polish remover if you just want to go around the corner.
Offline george graves
« Reply #5 on: October 05, 2012, 10:53:56 pm »
Nail polish remover often has an oil or something in it as a moisturizer, and fragrance - and it's much more expensive.
Offline nukie
« Reply #6 on: October 05, 2012, 10:59:00 pm »
Go to a paint shop get some acetone.
Offline Psi
« Reply #7 on: October 06, 2012, 12:29:49 am »
Anything designed to clean brakes will be very aggressive and not the sort of thing you want to use unless necessary.
« Reply #8 on: October 06, 2012, 02:26:14 am »
Not to mention - that stuff has to be really bad for the environment.
Sometimes I use some compressed air to blow off the pcb after cleaning with 98% IPA - I get noticeably cleaner boards that way.
