I've looked around internet and this forum for suitable reference designs, but so far in vein.
As there is quite a few wise men in here I hope I am hoping to get some help here
My background - lots of experience with embedded systems software design, not very confident with electronics as such.
Recently I got hooked on electro-chemistry and need a power supply to carry out some experiments
Some spec I would love to achieve:
- voltage -> adjustable, as stable as it can get in full range of current
- voltage range -> < 5V, most of the time around 3V, for some experiments down to 0.15-0.30V
- voltage precision -> 0.1V as bare minimum, 0.05 more desirable, I would love 0.01V
- current - adjustable, stable, precision much less important than voltage
- current range - less than 5A, most of the experiments around 2-3A
- current precision - in range 100mA (maybe even less) should be sufficient
I have built quite a few adjustable supplies on lm317/lm338, but because of voltage range it is not the way to go forward. I am not confident I can design analog circuit on opamps and darlingtons from scratch hence my call for help
Any reference you could post would be much appreciated.
Besides obvious goal of building the power supply I intend to learn something so next time I need to go analog I wont be so lost
PS. I searched for supplies of the shelf, but first they are expensive (all have range 0-15V or 0-30V, which way too much and I don't fancy paying for sth I don't need) and main reason - if I buy it I wont learn anything.
TIA
