Author Topic: looking for GOOD signal relays  (Read 1287 times)
Offline 001Topic starter
  • Country: aq
« on: September 11, 2018, 09:43:31 am »
I`m looking for GOOD  signal relays
for signals up to at least 100kHz
minimal resistance and capasitanse required
What common models will be ok for me?
Thanx
Offline Dave_C
Re: looking for GOOD signal relays
« Reply #1 on: September 11, 2018, 10:48:05 am »
On the top of my head:  FTR-B3 series from Fujitsu/Takamisawa.
Datasheet: https://www.fujitsu.com/downloads/MICRO/fcai/relays/ftr-b3.pdf
They specify it to have max 75mOhms of initial resistance but I can't find any capacitance specs.
Insulation and insertion loss vs frequency is specified ( attached screencaps from the FTR-B3 datasheet )
It is specified for at least 1MHz so at 100kHz it will perform even better
If you need better frequency characteristics then you would need to use a RF relay and they are expensive.
You might also find something even cheaper that suits your application.
The following users thanked this post: 001
Offline digsys
    • DIGSYS
« Reply #2 on: September 11, 2018, 11:21:13 am »
I've been using these - MSS21A12 - for over 25 yrs. They have mercury, so you know they're good :-) .. elcodis.com/parts/5358447/MSS21A12B.html#datasheet
Capacitance - 1.5 / 3.0pF     Contact Resistance ~50-75mR   200Hz   500x10^6 + operations
If they're suitable, I have many tubes at EOL you can have, only ~10-20 million operations left - I run them at 5Hz 24/7 for ever :-) picking up RFID
It's cheaper to give them away than the cost of recycling mercury !!
There are dozens of other types in their catalogue as well.
  • Country: aq
« Reply #3 on: September 11, 2018, 11:44:52 am »
Thanx a lot!
Online coppercone2
« Reply #4 on: September 11, 2018, 04:10:52 pm »
there are also RF relays which are coaxial and shielded and everything
https://www.mouser.com/Electromechanical/Relays/High-Frequency-RF-Relays/_/N-5g33/
