Hi all. Just looking to find out what these things are called. They go on the end of a wire that is then inserted through a pcb hole and the barb makes sure that the wire is held securely until it is soldered. I want to find out what they are called so I can get some drawings etc as regards what pcb hole size to use with what sized wire and crimp thingy.
