Author Topic: Feasibility of a small custom 1W SMT DCDC transformer for qty 1000  (Read 4530 times)
Online PCB.Wiz
Re: Feasibility of a small custom 1W SMT DCDC transformer for qty 1000
« Reply #25 on: March 31, 2024, 10:29:09 pm »
Is the Skyworks SI8751 actually useful for fast gate switching? I'm switching <200A split across 4 fets (DC load switch)
Looking at the datasheet, GATE On Impedance is 162k  and output voltage 10V.
Am I correct in assuming that using a SI8751 is equivalent to applying 10V to a FET gate through a 162k resistor ?
Depends what you mean by fast  8)
They spec 85us typ to 90% (9.72V into 100pF)
What is the gate capacitance of the FETS you use now ?  Do you need 10V gate drive ?
What isolation do you need from control side, and between units ?
I see TI have a nifty looking  UCC33420 PREVIEW  1ku  $1.300  in a 5x4x1mm SMD package.
5V/5V 1.5W 3kVrms isolated DC-DC module with integrated transformer
- not yet spec'd in higher voltages, tho they do older/larger models in higher voltages.
« Last Edit: March 31, 2024, 10:41:05 pm by PCB.Wiz »
Offline PsiTopic starter
« Reply #26 on: April 01, 2024, 04:15:51 am »
Plenty of similar isolated DC-DCs at LCSC for under a dollar :
https://www.lcsc.com/products/Power-Modules_634.html
You raise a good point.  Those are cheaper than what i'm paying.
However one of the reasons I want to replace these is they're SIP modules and I'm not entirely happy about the way they mount to the PCB in a line. They can wobble from side to side if pushed a bit.
« Reply #27 on: April 01, 2024, 04:21:13 am »
Yes, need 10V gate charge for 1mR Rds
Everything is just 12V so don't need any serious isolation at all.
There are 4 fets in parallel, so 28nF
TPH1R204PL1
Input capacitance 7200pF
Total gate charge = 74 nC (typ.)
Gate-source charge = 16 nC
Gate-drain charge = 17 nC
Gate switch charge =  17 nC
Output charge =56 nC
« Last Edit: April 01, 2024, 04:25:51 am by Psi »
Offline voltsandjolts
« Reply #28 on: April 01, 2024, 09:33:59 am »
How much do your DCDC converters cost?
I see Mornsun have +15V/-9V DCDCs for IGBT gate drives at around GBP3.50
https://www.digikey.co.uk/en/products/detail/mornsun-america-llc/QA153-1509R3/16643920
Sure, lots of jellybean DCDC for $1 but I was specifically looking for isolated with reinforced isolation, high CMTI and low coupling capacitance from one of the few cheap chinese DCDC brands that I have moderate trust in. That's not a $1 part. But seems like jellybean might be OK here, given low voltage.
« Last Edit: April 01, 2024, 09:43:21 am by voltsandjolts »
Offline Wolfram
  • Country: no
« Reply #29 on: April 01, 2024, 06:04:02 pm »
They do, but not with the isolation voltage (5000 VAC), isolation capacitance (3.5 pF) or characterized CMTI behavior (200 V/ns) of the QAxx3 series. Practically, it's not going to matter much if this application doesn't switch super fast, but even plain superjunction FETs at higher voltage can make enough dV/dt to cause trouble with improperly selected DC/DCs. 200 A suggests a lower voltage application where dV/dt won't be a worry, but it's something to keep in mind.
Note that LCSC list a range of converters with part numbers and specs identical to the Mornsun QA-series parts, and these are not meeting the specification at all. I tore down units from all the brands they list, and they were all done with plain magnet wire overwind and 30-ish pF isolation capacitance, compared to the double TIW and 3.5 pF of the original. Parts listed at Mornsun on LCSC should be the real deal.
The following users thanked this post: Psi, thm_w, voltsandjolts
