Although, high temperature solders are either really high (e.g., silver solders -- brazing, really) which seems unlikely, or soluble in regular solders (e.g., 90-100% Pb). Zn alloys have higher melting points, but AFAIK, don't touch electrical components, and wouldn't make good joints if they did (due to the solubility in tin but not lead*, and higher reactivity demanding a stronger flux).
So, that would just be a matter of soaking the joint for longer -- automated paste reflow might be okay (not too much dissolves, merely leaving a joint with a pasty appearance), but hand soldering with a little too much dwell and a little too hot iron will easily carry that risk.
*Yes, zinc floats on top of lead. This was used to extract silver (which is more soluble in zinc and therefore partitions into it) from lead before electroplating became the preferred purification method. However, enough tin will dissolve both (just as enough alcohol will bring water and oil together), but probably leave you with something unfit for soldering. This has been your Random Fact of the Day.
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
