Author Topic: Failed SSD Hard Drive Question  (Read 5471 times)
Offline madires
  • A qualified hobbyist ;)
« Last Edit: November 10, 2023, 03:00:17 pm by madires »
Offline bostonmanTopic starter
Re: Failed SSD Hard Drive Question
« Reply #26 on: November 10, 2023, 03:42:39 pm »
Wow....... Great video, thanks!
I don't know how many of these drives I have, but I better update the firmware soon. Thankfully I don't care about the data on this drive, so not much is lost.
Offline madires
« Reply #27 on: November 11, 2023, 03:35:31 pm »
Update from an Austrian data recovery company dealing with external SSDs from SanDisk/WD (https://futurezone.at/produkte/sandisk-ssd-ausfaelle-western-digital-attingo-datenrettung-problem-hardware/402664391, in German):
- broken solder joints causing components becoming loose
- poor solder or soldering process (bubbles)
- component packages too large for PCB layout
- later SSDs use epoxy for mounting components but still prone to failure
  (indication that WD knows exactly what the problem is)
« Last Edit: November 11, 2023, 03:54:40 pm by madires »
Offline moffy
« Reply #28 on: November 14, 2023, 09:25:06 am »
Not the same drive but a repair/recovery of an SSD due to failed cap. Good technique:
Offline 5U4GB
« Reply #29 on: November 16, 2023, 08:24:29 am »
