So, quick update on the project (I do not think it is necessary to create a new thread, right?). Here's a list of what I observed in the last few weeks:
1. When the RX coil is placed righ over the TX one, the coupled voltage is detected to up to 1 meter of distance.
2. The diameter of the wire does not seem to be really important.
3. Just like a transformer, if the RX coil has more turns it will boost the detected voltage. My TX to RX ratio is 30:75.
4. Adding a capacitor (matched to the coil inductance and frequency) in parallel to the RX coil significantly increases the amplitude of the RX voltage, but does nothing about sensitivity.
5. Balancing the coils is not that difficult, but with the capacitor in parallel to RX i cannot drop down to 10mVp.
6. Even trying to amplify the RX voltage, it get "more responsive" but not more sensitive in terms of distance.
7. Coins, keys and other small object that even the cheapest detector would detect, my porototipe doesnt.
8. Lower frequency from 5 to 10kHz that should be more effective in the distance does not work. I found that 15 to 22kHz is the best frequency to operate.
What I think I learned:
a. Many Induction balance detectors does not put much power to the RX coil, but highly amplify the RX coil.
b. A simple and cheap audio amplifier will drive the coil widouth any issue. I currently use TDA2030A and achive almost 30Vpp to the RX coil.
c. A matched capacitor on the output is impossible to connect since the amp output will start oscillate.
d. I do not think that i need to increase the RX power.
e. Conditioning the singal seems to be useless.
I am feeling pretty discouraged right now and really do not know what to do to obtain some decent resoult. I will keep triying and keep you posted. In the meantime I attach to this post an updated image of the coils and some extra info:
RX coil: 75 turns of 0.5ish mm diameter, not shielded (a cable wraps it and it is not closed to itself), measured induction is 2.42mH;
TX coil: 30 turns, same as above, i did not measured the inductance but i expect some 1mH;
Anything you can think of, please share!
