Author Topic: Experimental 48V->200V boost  (Read 5443 times)
Offline uer166Topic starter
« on: June 13, 2020, 09:00:24 pm »
Finally came round making my first power electronics project, and would like comments/feedback. As part of a 48V DC to 120V AC inverter I made a 2-phase boost converter to try things out with. It uses homemade litz-wound MPP-core (0055550A2 cores from Magnetics, mu=26). Currently I have some nice 50mOhm IXYS FETs and some schottky diodes. Switching frequency is 100Khz fixed for now. Goal is primarily efficiency and simplicity but without being too $$.
The control is cycle-by-cycle peak current mode with a low-side shunt on the FET source. I had to do leading edge blanking and all that. The outer voltage loop runs at 1/10th of the Fsw and just sets the DAC value for the peak current control. I randomly tuned a PI controller, seems stable enough and okay transient response, even from 100%->0% load. Some challenges I faced:
  • The embedded STM32F303 opamps seemed to be absolute garbage with 10mV input offset, and weird artifacts when outputting near the GND rail. By the time they started outputting anything, the current is already at 1A. I manually twiddled the trimmers in the opamps to fix it, the internal calibration routines didn't make it any better. Did anyone have a similar issue? No matter what I do I am unable to reach datasheet performance, even with randomly twiddling the high and low trim values.
  • Because of the opamp's DC offsets, it was possible to lose regulation since at no-load condition, there was a minimum duty cycle below which the peak current mode control wouldn't go, outputting unlimited voltage (bye-bye Rigol e-load  :'(). How is this fixed usually? Some sort of burst mode control? How would that look like in C code?
  • Efficiency wise, it doesn't seem to be too bad for a first pass with some tweaks, but I want to get to 97% at least when going 48V->170V. The inductors' AC resistance at 100Khz is about 0.25Ohm at 100Khz reported by a Bode 100, and only ~40mOhm at DC. Is there a better way to wind them to get AC losses down? Currently it's 3 layers of Litz. Would synchronous rectification help here? (I'm moving to sync anyway because I need bidirectionality, really hope it helps).
  • Are there any easy (Engineer-oriented, not research papers) to understand resources to design an optimized compensator for this kind of thing? I can easily understand peak current mode control, but the outer voltage loop design is a bit of a mystery. 2p2z, lag compensators, maybe I just need to convert a type 3 compensator to digital domain somehow?
Next steps are: slope compensation, it's wayyy too chaotic for my liking when it comes to the subharmonic oscillations, since this is always operating at ~75% duty cycle. Tests at full power (600W with both phases interleaved continuous, 1200W peak). Experiments with different inductor designs and other parts.
Offline TheMG
Re: Experimental 48V->200V boost
« Reply #1 on: June 14, 2020, 02:59:09 am »
Switching regulators/PSUs going out of regulation when under very light or no load is a problem that has been around for as long as SMPS technology has been around. In the early days, a common trick was to add loading resistors on the output sufficient to keep the output voltage in tolerance when the external load is disconnected. Of course, this sacrifices efficiency so this approach is rarely used nowadays. Burst mode operation is very commonly used, and most switching regulator ICs support some variation of it.
How to code that... no idea. Seems to be an awful lot of effort writing code for this task when there are already plenty of commonly available ICs that are designed to do exactly that!
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 14, 2020, 03:36:31 am »
Oooh, fancy!
Easy, add a bias resistor from +3.3V to PH1/2_I_SENSE to bias it up off from GND. ;D
Probably a good lesson to not rely on MCU internals too much, especially analog ones.  They're often crap.  It's a minor miracle that 12+ bit ADCs are even possible, let alone reasonable.  Read the datasheet very, very carefully, then read the manual(s) and peripheral docs, then read the datasheet again, then read the errata.
Other things to watch out for -- poor POR (particularly on slowly rising supplies), poor VREF (ATMEGAs most notoriously), differential receivers with uselessly little CM range (even proper ADCs, the fast differential-input ones; FPGAs, and some MCUs, with LVDS or similar interfaces), etc.  Most anything Microchip, analog and digital included (PIC, etc.; excepting Atmel, at least for now).
And not really a bug because it's well documented, but different from usual: ST's crystal oscillators tend to be quite weak, so need a higher impedance crystal, and smaller shunt capacitors, than most.  I guess that's not relevant here as you aren't using it, but still something else to watch out for.
Again, offsetting the input will help, but also, you didn't have a hard voltage limit or anything?
This is kind of one of many reasons why I still haven't written a software/hybrid controller yet.  I will eventually, but it definitely hasn't been necessary.  There are too many complexities in the systems themselves, and too many edge cases in the software, to write one with a reasonable guarantee of operation.  All it takes is a few flipped bits and it's off in la-la land and the output explodes or whatever.
A very good idea is to add logic gates between the MCU and gate drivers, so that a hardware disable function can be implemented.  This should be driven by a fault latch, which is reset when a hardware failure signal fires, and only cleared by a suitable sequence of operations from software -- at that, an ongoing sequence, so it serves as a watchdog timer.
Typical hardware detection events would be: leaving an output on too long; letting a switch carry more than some maximum peak current; letting the input or output voltage rise too far (speaking of which, keep the input in mind when you move to synchronous mode operation -- it's a boost and buck at the same time!); maybe a hard thermal limit, external fault input signal, supply UVLO, etc.  Lots of possibilities.  The less software, and the less high-complexity hardware, involved in each, the better.
Ideally you'd have hardware that just runs everything by itself, and the MCU just tells it how much current or voltage to run at.  You could drop in a pair of UC3842s and use them in this way -- strap the error amp as an inverting follower and set its current setpoint from a DAC.  It runs the oscillator and switch by itself from hardware functionality alone.  (UC3842 family exactly, isn't the easiest to synchronize with phase interleave, and takes a somewhat high CS voltage (1V nominal max, of course you can use the pull-up trick to ease it a bit, or preamp it), so this might not be a directly applicable example.)
I digress... :)
As for burst mode -- you need an accumulator to store state (in this case, probably the PI control's integrator).  However it's done, there's some range of input values where the output (PWM compare register) does not change but remains fixed at some minimum value, or is disabled completely (set to zero or whatever).
The minimum pulse width vs. disabled condition might be by direct timing (the input value could be turned into a PWM signal generated at a fractional clock rate), or as part of a feedback loop (hysteretic control) in which case the feedback variable will realize the same function (namely, the control integrator will hunt).  Or both (the fractional rate PWM could actually be a sigma-delta converter?).
if (pid_output >= PWM_MINIMUM) {
PWM_COMPARE = pid_output;
} else if (pid_output >= PWM_MINIMUM / 2) {
PWM_COMPARE = PWM_MINIMUM; // set to minimum pulse width
} else {
PWM_COMPARE = 0; // disable PWM channel
And also clamp to a PWM_MAXIMUM, so you don't accidentally, y'know, leave a switch latched on forever or something. ;)  Maybe not strictly necessary for a peak current mode control -- the current simply rises until you switch it, and if it never hits a useful let alone dangerous current, who cares? -- but can be helpful to soften some edge cases.
Core datasheet: https://www.mag-inc.com/Media/Magnetics/Datasheets/0055550A2.pdf
What is that, 63 turns I count?  So 111uH nominal, and 15A at -20% saturation, 25A at -50%.
And 48V 600W is 12.5A, but I don't know what minimum input voltage might be.
At 100kHz, CCM, 96V output, that's 125uVs peak flux change, or 30mT flux density.  They give a figure of 0.8W/cc or 4.27W dissipation at 100mT and 100kHz; if this follows square law, then your dissipation should be around 0.5W, more at high duty cycle but maybe not much more than a watt.
125uVs / 111uH = 1.1A peak, or about 56 VAR; dissipating <1W means a Q of >56.
And X_L = 70 ohms so a Q of >56 implies ESR < 1.24 ohms.
0.25 ohm, albeit at a very small signal level I suppose, seems very fortuitous, and is in the right order of magnitude.
I wouldn't have bothered with Litz as the AC resistance doesn't matter much -- again, you're only doing 50 VA or so.
And yes, you can think of a switching circuit in RF or AC terms just fine -- I don't know that many authors use VARs as a working figure, but it can be defined just as well here as anywhere else.  There are some sqrts missing because of the waveforms (current is triangular), or you can do it by harmonics (Fourier series of square and triangle waves of some duty cycle, Parseval's theorem), also ideally you'd check losses for each harmonic because the inductor itself isn't perfectly linear with frequency and amplitude, but also if it's nonlinear, how do those harmonics interact, arggh?!..., but anyway even if it's just a ballpark, it's the same shaped ballpark for every non-resonant SMPS so it's useful for comparison.
The various types are still single order overall, so just consist of different coefficients of accumulating to a register with feedback, and differencing against previous samples (but not accumulator chains, or many previous samples).  There are simple transforms between lumped equivalents (error amp compensators in s or F domain) and DSP expressions (Z domain).
So for example, at most two biquads and an integrator might be used (with one biquad, or simpler, being typical); though the coefficients for that form might be nontrivial to solve from a circuit, and a more closely equivalent form might be preferred.
I don't know if anyone really does DSP control this way, with traditional signal filtering rather than PID, but there is a lot of compatibility in their response so I don't see that being a problem.  Signal filters are just on my mind as I recently implemented a thing.  Whichever works.
It's hard or impossible to solve for compensator parameters without academic background; IIR filters especially as their polynomials lie within the unit circle, not just the left half plane.  Polynomials are the problem space here, so it's at least not your fault that solutions are difficult to work with. :P
I mean, all filters can be represented by polynomials in some way, I think, given enough generality.  The exception for FIR filters is more that they're actually pretty easy to understand as a convolution process, which maybe sounds scary until you've seen how it works.
So, two things --
1. App notes always say 50% duty, because appnotes are almost always written by interns, or 2nd rate engineers ("those that can, do..."?).  What they mean to say is CCM.  Which in the usual simplified setup, is 50% duty, for a boost with Vout = 2 Vin, or flyback with Vin = Vout, or...  Well yeah, doesn't matter what the exact duty is, that's stupid, what matters is its relation to Vout/Vin, or whatever x/(1-x) variation applies to the topology in question.
2. You're running way too low a ripple fraction for peak current mode anyway.  600W output for 56 VAR switching energy?  1.1A ripple for 12.5A input?  Same thing, ~9% ripple fraction.  Great for keeping inductor losses down -- hence the low VARs -- but PCM goes chaotic in CCM, and you can introduce slope compensation but it's really not putting you very far down, you can go to 50%, maybe 30% ripple fraction without the current limiting behavior getting too terrible.  Beyond that, you should really consider using smaller inductors (which will have to be much higher Q, of course, among other things*), or average current mode or something like that.
*The input and output ripple go up accordingly.  Boost output filter cap ripple is always at least 100% (i.e. 0 to Ipk), but it goes up noticeably with ripple fraction, while boost input ripple is simply inductor ripple.  In other words, the VARs from the inductor are stirred through the supply.  The AC voltage drops on the capacitors are supposed to be small, so the VARs they deliver are much lower, but their Qs are much lower too (electrolytics top out at maybe 5 or so) so they can get quite hot in the process.  Just another way of saying, mind your ripple ratings, of course!
Average current mode is very easy to implement.  Read the inductor current with an ADC.  Doesn't have to be synchronized with the switching frequency, though if you can sample mid-cycle (to get the mean current, aliasing the AC ripple to zero), or 2*Fsw (so the AC ripple is measured just perfectly, and can be decimated to zero with a two-sample average), that's nice.  Anyway, run an error amp on that, to control inductor current to the setpoint, then control the setpoint with a voltage error amp to regulate voltage.  Done.  Can't be simpler, just two cascaded loops.  No comparators, no nonlinear switching, no latches, just a PWM oscillator.  Easier to phase-interleave, I would suppose.
The hard part then is measuring inductor current.  You can measure switch current, and infer inductor current during the off phase, but this breaks at low currents -- in DCM.  (You also won't be able to sample exactly in the middle, for some sufficiently narrow pulse width.  Or it'll all be transients, which have to be blanked, or at least filtered out.)
You can measure diode current and add it to switch current.  Connect a current transformer in series with the diodes.  CT secondary is wired-OR, using a diode, into a common burden resistor which can be a portion or whole of R19 and R20.  Thus the diode current sense adds to the switch current sense.  Downside, there's a transient gap where neither current is quite right (especially if the CT has shitty resonances in it), and it doesn't work at very low duty cycle (where the diode current is active for so long, the CT doesn't have time to reset its flux).
Or you can measure inductor current directly.  If the supply doesn't need to be common ground, add a low side shunt resistor.  If it is, you can use a high side current sense amp, or Hall effect sensor.  I would prefer the latter, since it works to quite high supply voltages with no worries.  HE sensors do tend to have poor bandwidth, which limits response time and means your filter network should have less bandwidth than it -- but that's quite fine as, with so much inductance, you have a loop bandwidth probably crossing over at Fsw/5 or less, and most sensors have 100kHz or more BW.
You might have to rewire your circuit to use ACM control, or if the STM32 has enough analog mux options maybe not even that.  The current transformer method would be, eh, not terrible to hack in, otherwise the Hall effect sensor can be wired in wherever and R19/20 DNP'd to make the connections.
Finally, for the bridge, you may consider snubbing, perhaps a quasi-resonant rate snubber or something?  It can be hard to use these, just in general, for one, but also when you don't have conveniently split supplies or whatever.  They also tend to need a lot of components, so the sheer component body and lead lengths accumulate so much stray ESL that they aren't effective anymore.  Not a slam dunk, just something to look into.
Seven Transistor Labs, LLC
The following users thanked this post: Wolfram, uer166
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: June 14, 2020, 03:50:26 am »
The usual approach is to suppress switching activity if the output voltage is already above the setpoint by some margin. The margin is generally chosen such that it would be unlikely to be reached during normal load operation. That can be something like 180V for your application with 170V being the normal setpoint.
What kind of load are you planning to run? If it's primarily motors, you can add the option to output 100V/50Hz (or any point on the line between it and 120V/60Hz) which will reduce the bus voltage to 140V or so and reduce the power drawn by the motor.
« Reply #4 on: June 14, 2020, 03:57:36 am »
The goal of the project is, as the title implies, experimental. Eventually I would like to morph this into a synchronous one-stage boost inverter, but really, it needs to stay as flexible as possible so I can try out all kinds of digital SMPS algorithms. But also, by the time you figure out how an off-the-shelf controller IC works, you could have rolled your with less risk of "that one little detail that breaks the entire design".
Going through Tim's wall of wizardry right now..
Edit: to answer the question about hardware overvoltage (due to my impatience), I do have it, it is set to 170V via a resistor reference and internal comparator, and trips the hardware "break" input that disables all switching. Unfortunately my Rigol e-load only went to 150V, so I guess max. load and slight overvoltage =  :-BROKE. I didn't blow a single part on the actual boost converter yet, even with all kinds of abuse, over many different FETs and diodes.
« Last Edit: June 14, 2020, 04:00:06 am by uer166 »
Offline jbb
« Reply #5 on: June 14, 2020, 07:42:22 am »
Oh, you shouldn’t have said that :D
There are some interesting digital control methods you could have a look at later, such as trajectory control methods (controls behaviour on inductor current / capacitor voltage plane) and model predictive controls (lots of offline computation to produce a variable gain control scheme for optimal response).
« Reply #6 on: June 14, 2020, 06:56:43 pm »
Mmh yes this obvious math makes a lot of sense.. Let me just convert it to something practical real quick  :-DD
« Last Edit: June 14, 2020, 06:59:20 pm by uer166 »
« Reply #7 on: June 14, 2020, 07:48:15 pm »
Aaand burst mode was a lot easier than I thought, I originally almost went with an overly complicated fixed frequency scheme, but this:
 // "Burst" mode for low load
 if(ph1_current_setpoint < 20)
   htim1.Instance->CCR1 = 0;
   htim2.Instance->CCR4 = 0;
 else
   htim1.Instance->CCR1 = MAX_DUTY;
   htim2.Instance->CCR4 = MAX_DUTY;
Works surprisingly well, maybe 0.4V ripple or so.
« Reply #8 on: June 15, 2020, 10:11:04 pm »
Well it was nice while it was working. I tried a full load test at around 900W (450W per phase), interleaved, and the diodes kept failing short. Tried again at 600W (300W per phase), same result. I'll admit they're a bit undersized, I tried some 5A rated schottkys and 2A rated ones. The failure happened about 10 seconds after switch-on every time, so they must be overheating..
I also tried replacing the diodes with the same IXYS FETs (IXFY26N30X3), using their body diodes only (gate shorted to source), and now the MCU resets after a few pulses, it seems like the hard reverse recovery is pretty massive, this will be a problem for the synchronous version. Not quite sure what the mechanism of the reset is, I'm having a hard time probing since even with a low-inductance GND lead I see like 15V common mode noise on the scope :(.
Also tried some snubber experiments, albeit with leaded resistors and 1206 caps, they don't seem to be too effective at 130MHz. Any ideas how to probe things properly? Again when probing GND with the low-inductance lead, I still see big transients (15V+ when should be 0), therefore I can't really trust any measurements. The entire thing is floating, except when being probed, then the -ve rail is grounded to mains earth via the scope.
Maybe a lot of these issues are to do with the low-side FET having a source resistor to measure current, so there are big voltages generated across it. In future I will have isolated gate drivers with non-isolated bootstrap power rails, that should help as well?
« Reply #9 on: June 15, 2020, 10:25:14 pm »
Some traces of Vgs, Vds, and across the 20mOhm shunt..
Offline ocset
« Reply #10 on: June 16, 2020, 04:46:21 pm »
I did a quick LTspice representative sim of one of your Boost stages, and its as attached if you wish. (it mightn’t be too accurate due to your using a non linear inductor). If I were you id use ferrite….will make the slope comp easier to calculate.
170V is quite high for a boost output voltage, and I reckon your reverse recovery losses in the fets and diodes will be too much.
(as you know, diode rev rec will also heat the fet in a booster)
Youll probably have to increase the fet gate series resistor enough so that you reduce the reverse recovery spike a bit.
Reverse recovery is the grim reaper of high power / high vout boost converters in CCM
But in truth, with  deep CCM , and your high vout, you need SiC diodes, and bigger ones than you have. I couldn’t find the datasheet for your E5… diodes.
As you know, with hard switched topologies at fairly high power, and   in deep CCM, you especially need to tune the gate drive series resistor and current sense filter, otherwise the power supply  just wont work… it  will get swamped with noise.
I think you need a decent heatsink directly on the fets and diodes…not just going through the FR4 to a heatsink below (?)
I would use a current sense transformer aswell (like T3sl4co1L said) ..they do  give a less noisy  signal than a sense resistor,and good for high currents.
beware also using fets in parallel.....check you dont have vgs ringing too much...but you seem to have checked this.
The pdf attached tells how to calculate slope comp
Theres a current sense txfmr sim attached too (in ltspice)..its for a forward but its the same type you shoudl use (i think Tim maybe already said this for you)... The CST will have to go in the drain connection of the fet, which is a noisy switching node, but it has to go there.
I am sure you are aware....the CST inductances and turns ratio has to be correct, otherwise your current sense signal may  slope down instead of up.
So i hope now you are up on the absolute curse, the absolute SMPS graveyard, which is "reverse recovery in high voltage Non isolated converters" (In isolated ones, the leakage inductance catches/staunches the leakage spike a bit)
Those little 4by2mm (non SiC) diodes that you originally had, would have wanted to  run off the board screaming in truth.
« Last Edit: June 16, 2020, 05:21:26 pm by treez »
The following users thanked this post: uer166
