Havent used either, but a lot of pick and place machines need a leader/trailer so they can run the tape though the appropriate path, hence the re-reeling service by digikey/mouser. Some machines dont need a leader though, so you can feed cut tape into them as needed, or some assembly houses can re-reel cut tape for you (for a fee of course) Check with your assembly house.
