Author Topic: Experience with Digi-reel  (Read 8330 times)
Offline michaelymTopic starter
« on: May 15, 2014, 12:26:53 pm »
Does anyone have experiance good or bad with Digi-reels or MouseReel?
Do assemblers prefer cut tape?
Offline ConKbot
Re: Experience with Digi-reel
« Reply #1 on: May 15, 2014, 01:15:00 pm »
Havent used either, but a lot of pick and place machines need a leader/trailer so they can run the tape though the appropriate path, hence the re-reeling service by digikey/mouser.  Some machines dont need a leader though, so you can feed cut tape into them as needed, or some assembly houses can re-reel cut tape for you (for a fee of course)  Check with your assembly house.
Offline Neilm
« Reply #2 on: May 15, 2014, 07:23:13 pm »
I have used them - they mostly worked. Sometimes the leaders are not joined very well to the reel which can cause issues but mostly they worked OK
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline nickm
« Reply #3 on: May 16, 2014, 03:35:26 am »
I tried to save money by just ordering about 25 extra pieces of cut tape for each cheap passive on a build.  On a couple I ended up with several small pieces of cut tape which added up to the total I ordered, but could not be used at all.  Turns out when they say cut tape they don't garentee that it will be one contiguous pieces of tape.  I might have ended up saving money since the 25 extra pieces on each passive was nothing and paying 7$ per would add up quickly.
Offline calexanian
    • Alex-Tronix
« Reply #4 on: May 16, 2014, 03:45:41 am »
On passives i try to buy full reels. For resistors it makes no sense since a whole reel is typically $15 or less. For i.c.'s its a pretty good deal though. The assembler we use has had good luck with digi reel's I have sent.
Charles Alexanian
Alex-Tronix Control Systems
Offline JoeyP
« Reply #5 on: May 16, 2014, 09:30:24 pm »
^This has been exactly my experience as well.
In general, cut tape is a pain in the ass, and almost always results in wasted parts and extra labor costs.
