Author Topic: Solar PV Curve Genorator  (Read 2266 times)
Offline House91320Topic starter
« on: June 26, 2013, 08:00:20 pm »
I need a a power supply that will simulate the pv curve of a solar cell, dose anyone know of a good circuit to do this?
Offline ejeffrey
Re: Solar PV Curve Genorator
« Reply #1 on: June 26, 2013, 10:30:17 pm »
Depends on what you need, but a constant current source shunted by a diode is a pretty good model.
« Reply #2 on: June 26, 2013, 10:58:42 pm »
That's what was thinking thank you.
Offline ftransform
« Reply #3 on: June 26, 2013, 11:35:27 pm »
says the vampire
Offline Harvs
« Reply #4 on: June 27, 2013, 12:45:58 am »
Depends on what you're trying to do with it. Obviously implementing the single diode model as a CC across a diode doesn't shift much in its characteristics (other than adjusting the current of course.), that may or may not be of any significance to you.
If you want it to match a certain cell a bit more closely you can easily tune the slopes of the IV curve by adding in series and parallel resistance like the single diode model has.
