Author Topic: Dimensions of DC barrel power jack compatible with 5.5mm, 2.5mm male connector  (Read 1096 times)
Offline sabihaTopic starter
  • Country: in
Hello,
 I would like to know the dimensions of female DC barrel power jack compatible with a male connector of 5.5mm OuterDia;2.5mm InnerDia.
Find the attached male connector and female barrel jack for the reference.
Please help me in this regard.
Thank you.
Offline sokoloff
Your question seems to assume that there is *ONE* answer. There are a variety of manufacturers and each is likely to be slightly different.
I'd go find a matching part (sample: https://www.digikey.com/product-detail/en/cui-inc/PJ-037B/CP-037B-ND/1644546 ) and look over the datasheet and/or CAD model for the specific part that you're going to use.
