Author Topic: Copy an existing, populated, PCB board?  (Read 5477 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: September 19, 2012, 01:20:13 pm »
I have a small and simple plug in PCB board from a power supply on its way to me, inside a partially working PSU. It is the same board that is missing altogether from a sister none working supply I have, that gives a hefty 60 volts, 50 amps variable output that I want to fix. I could de solder and remove all the components off the board I am getting, and thought I could maybe take some sort of "brass rubbing" tracing of the tracks, but is there a better way? I would like to try and etch a board myself but have never tried anything more than very basic stuff of my own design, with the tracks blanked of with cut vinyl tape, or marker pen. Thanks.
Best regards,
                 Chris Wilson.
Re: Copy an existing, populated, PCB board?
« Reply #1 on: September 19, 2012, 04:20:31 pm »
Good digital camera and a pair of rulers on the board edges. Photograph from above, with an even light to illuminate the board, and use a graphics program to convert to a greyscale and posterise the image to a black and white image, with the traces in black and the board in white. Scale to the right size and print as an image and use a photosensitive board, or send to a PCB house to do. Check the tracks match on a test printout, and when correct you can get the board made and drill it yourself.
Offline grumpydoc
« Reply #2 on: September 19, 2012, 04:25:18 pm »
Single or double sided.
I've been thinking of the same for a couple of PCBs - and pretty much planning on using the process outlined by SeanB. It possibly helps that I have a copy of photoshop to tweak the image.
« Reply #3 on: September 19, 2012, 04:44:34 pm »
Single sided and quite uncomplicated. Will give it a shot when it arrives, haven't played with photo sensitive boards yet, wouldn't mind having a go with that too though! Thanks again Sean, great info, and appreciated.
Best regards,
                 Chris Wilson.
Offline krivx
  • Country: ie
« Reply #4 on: September 19, 2012, 05:45:33 pm »
I have used a flatbed scanner to scan  PCBs in the past. It works much better than a digital camera, the level of light across the board is very even and there is very little distortion. If you put a reference object (say, a ruler) on the scanner at the same time it makes rescaling the image for correct dimensions pretty straightforward.
Online AndyC_772
« Reply #5 on: September 19, 2012, 05:54:56 pm »
Even if you don't, there's always GIMP.
http://www.gimp.org/
Offline Bored@Work
« Reply #6 on: September 19, 2012, 06:40:59 pm »
Hire a dodgy "PCB cloning", "PCB reverse engineering" company from China.
