Okay cool you want a quiet supply. How quiet, then? Can you put a number on it?
Taking your request at face value means < 0 dBa, the very definition of "audible": right on the edge of perception. And given the frequency extension, that might be flat, not A-weighted.
That's really quiet, like, that rules out most capacitors as well as inductors, because they buzz just perceptibly at mains harmonics. It might need acoustic shielding to meet that (e.g. potting the supply, then suspending that inside a larger metal box with foam inbetween -- some means of heat transfer is still needed of course).
Easiest way to eliminate light load whine, put a dummy load on the output. Some synchronous rectifier architectures can run continuous wave as well, but you'd have to hack it to do that, or make your own.
