I understand the point you were trying to make, its not fair to compete against cheap shit from asia sold through dummy retailers who dont care about CE or FCC etc.
Exactly. And please mind that I know Italian retailers that aren't dummy, but well regulated ltd. companies, with their responsibility. The CE directive is well clear: the manufacturer and the retailer ARE responsible for what they put on the market. So I ask: if they sell crap things, shouldn't they be prosecuted by law? And since the answer is YES, why they continue to operate without any fine?
Without a solid, unbroken ground plane, you're just asking for trouble.
just for test, I've tried to route the PCB with 4 layers, 2 inners with the signals and 2 outers grounded like the literature suggest to keep all the emissions inside.
Forgetting that I should modify some trace witdh, the result is that I need another 2 layers since the pre-routing fails (many ratlines impossible to route). Apparently there are too much components and nets on the board for only 2 inner layers. So I should use 6 layers... Of course in this case I can't manage the costs, at least for a niche product like this.
Back to the main thread, I quickly summarize my goal: pre-test my device for radiated EMIIf I was a firearm manufacturer, and had to deal with power limit of 2000J for my new handgun, I would obviously need instruments to measure wich energy my new product has.
Without having a chronograph to measure the bullet speed and a scales to know its weight it would be hard to calculate its energy
in numbers.
But I need to know ONLY if I'm UNDER the 2000J limit, I don't need to know the value.
I can measure the power of a "compliant" firearm and compare it with mine. I can shoot to layers of cardboard until I find how much layers stops the bullet of the "compliant gun". At that point, if my gun, using the same projectile, DOES NOT penetrate more than 3/4 of layers than the number the compliant gun does, it's mathematical to have a compliant gun.
I cannot declare how much energy my gun has, but I can state safely that its under 2000J.
Applying this logic in my case I've thought this method:
1. use a cheap, uncalibrated spectrum analyzer (RF Explorer 27-2700MHz), near field probes and diy log periodic antenna (with preamp) in a "RF quiet" basement
2. compensate the uncertain calibration of the instruments by collecting radiated emissions
from similar EMC-certified devices, setting
the lowest value as emission limit
3. use this values as a threshold for radiated emissions
4. test my device with the setup and see if something goes over the threshold.
So now I have:
1. a testing setup
2. a threshold value to be observed -
I understand that I have NOT a calibrated hardware but his spectral response MUST have the same linearity with my product both with CE compliant product, so knowing the "limit value" to observe, it should be idiot-proof to know if you're exceedings the emissions.And at this point in my mind the REAL point is the following:
if I find that my product emissions are
well below (I said WELL BELOW!) the threshold,
even with an uncalibrated cheap setup like this I cannot be wrong: the device is EMI compliant.
At that point, how much sense does it have to pay € 900 for a certificate that states it's compliant when every product, by law, can benefit of the "presumption of conformity" (where the unconformity
must be proven by the authority)?!?! And even if the autority tests my device, how can they prove that is not EMI compliant when it's measured that it radiates less than CE approved products?
I'm well documented in this and even a EMC center consultant that I've asked to told me that there is no law that prescribe mandatorily an EXTERNAL EMC test with a report. It's a choice every manufacturer does. You can do it internally and if you're sure, you can declare it as compliant (and take all the responsibilities, the same is if you pay for the EMC test, it's ALWAYS your responsibility). I know "nothing ventured, nothing gained".
I know and I'm sure that is something that I'm missing, otherwise we wouldn't have so many EMC test centers and all manufacturers could save much money doing thinks like I say
So could someone please explain where my lack of knowledge makes me feel so safe?EDIT: with his great uCurrent sold all over the world (so even in EU) Dave has gone thru all this annoying EMC testing?
