Author Topic: will this work?  (Read 550 times)
Offline p.larnerTopic starter
will this work?
« on: April 06, 2024, 07:59:11 am »
I ordered 2 transfos from aliexpress 230v pri sec 12-0-12v,ie 12 volt center tapped secondarys ,they sent ones with 12v secondaries with no center tap,so its a nogo sending them back,so can i wire there both primaries in series,then link the secondaries,using the link as a center tap,for +12/-12v,hope it makes sense,its only a load for swithching relays in a psu kit.
Offline moffy
Re: will this work?
« Reply #1 on: April 06, 2024, 08:42:01 am »
Wouldn't you want the primaries in parallel otherwise if in series the secondaries will become 6V RMS windings? If you wire them with the primaries in parallel and link one terminal of a 12V RMS winding to one terminal of the other, phasing might be important, just make sure you have 24V RMS across both windings when they are connected.
« Last Edit: April 06, 2024, 08:43:33 am by moffy »
Offline Andy Chee
Re: will this work?
« Reply #2 on: April 06, 2024, 09:44:39 am »
It’s possible to use a voltage doubler configuration to obtain +/-12V dual rails from a single 12VAC winding.
But if you’re only powering relays, that normally doesn’t require dual rail supply.
Can you post a schematic?
The following users thanked this post: tooki, p.larner
Online Gyro
Re: will this work?
« Reply #3 on: April 06, 2024, 09:55:09 am »
You description is not at all clear. If you order 12-0-12V secondaries, then you shouldn't expect to receive center tapped 12V ones (6-0-6V).
Please post a clear diagram of what you want, labeling all voltages, together with clear photos of the transformer, including labels.
Best Regards, Chris
Offline tooki
Re: will this work?
« Reply #4 on: April 06, 2024, 11:24:20 am »
12-0-12 is a center-tapped 24V transformer.
The following users thanked this post: p.larner
Re: will this work?
« Reply #5 on: April 07, 2024, 09:07:31 am »
The transformer is the aux one in the schematic attatched,the orig is slightly wrong but it makes the point,basicaly i have a bunch of 12v secondary transfos that i need to use for the aux transfo in the psy schematic.,sending these back to china is a no brainer!.
Offline DavidAlfa
Re: will this work?
« Reply #6 on: April 07, 2024, 09:36:51 am »
Connecting the primaries in series will lead to 6V+6V instead your intended 12+12.
Primaries must go in parallel, secondaries in series, emulating the center tap.
Just like this:
« Last Edit: April 07, 2024, 09:38:29 am by DavidAlfa »
