Author Topic: What core alloys are most typical in audio and power (50/60hz) transformers?  (Read 560 times)
Offline ELS122Topic starter
I rarely found even mentions of core materials. Only that "you can't just use a power transformer as an output transformer it will sound like crap"... Which I know it does. But I'd like to have some insight as to why. What core alloys are used for mains power transformers and what are used for audio output, and coupling transformers?
Offline oz2cpu
    • webx.dk private hobby and diy stuff
the best audio transformers i find at
https://www.lundahltransformers.com/
They got several good pages about technical stuff
they are normally also keen to answer technical questions,
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
The following users thanked this post: ELS122
Offline Benta
Generally iron with around 3% silicon.
For audio, grade is typically M111-35N rolled and treated to be anisotropic (="grainy").
What does the grainyness accomplish? is it like air gaps throughout the whole transformer allowing it to be more magnetized before saturating?
Offline jonpaul
  • EE for 55 yrs
Hello been designing asnd building for production transformers since 1980s.
1/ Mains 50/60Hz:
0.014" silicon steel laminations are used for low eddy current losses, and high inductance.
Designs can be optimized for a Trise/ambient and to minimize core loss, but tradeoff is cost and avaiablity.
Laminationsfrom Tempel Steel, etc.
Alternative s tapewound toroids or tapewound cut core, but similar or small thickness.
Vendors like Arnold and Magnetic Metals. VERY costly but smailler size and lower losses.
All except toroids are asy to gap is needed.
2/ Audio: To achive a wideband transformer, with good LF response you need a large core area and very thin laminations or tapes.
Bell Labs developed high per materals like Supermendur in 1950s.
The cores are special lams or tapewound trorois or cut cores.
Vendors can be Vaccumsmeltz in Germany or Arnold, Magnetic Metals, etc,
Expect special windings and some small guage wire.
3/ FabL Bobbin and toriod winding machines are automated nowadays but hand machines are also used.
See Micafil /Metor in Switzerland or Adams Maxwell in USA for winding machines.
Bon Chance!
Jon
The Internet Dinosaur
