Author Topic: Electrospray ionization - ion trap - detector  (Read 643 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: September 02, 2019, 10:10:25 pm »
Hi all! So, this is an idea that's a bit out there, I just wanted some feedback if it might be worth pursuing.
I'm on an ongoing quest to construct inexpensive detectors for gas chromatography/ liquid chromatography/HPLC
There's a lot of development in this area, since most common detectors for liquid chromatography (UV-VIS diode array detector, mass spectrometers, conductivity, refractive index etc.) are usually very costly and bulky.
Basically, any detector that can detect peaks of dissolved molecules in a flow of liquid.
Here's the idea: Make a mass spectrometer without the spectrometer.
- Everything is housed in a very high vacuum chamber. Evacuated with a small turbo pump.
- An electrospray ionization source to create a jet of charged particles. most of the solvent is removed here.
- Maybe a simple electrostatic DC ion trap to suck away the lightest ions, acting as a mass low pass filter (might be needed to suppress solvent signal)
- Faraday cup detector, femtoampere-scale amplifier, ADC.
Do you see what I'm getting at? In theory, if you are certain only one compound will enter at a time you could in principle do away with the mass separation - you'd just want 'total amount ions other than solvent' as a function of time. Kinda like how a single wavelenght UV absorbance detector just detects "total amount of solutes at 255 nm" or similar.
This would be mechanically much more straight forward to construct.
--Chris
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline vindoline
Re: Electrospray ionization - ion trap - detector
« Reply #1 on: September 03, 2019, 07:19:26 pm »
Not "out there" at all. I'm pretty sure that this is what we call a "total ion chromatogram" or TIC. It's a pretty good universal detector.
    • My channel:
« Reply #2 on: September 03, 2019, 09:35:48 pm »
Thanks for the feedback!
Yeah the output would be the same, but that's usually just a data display type from a regular chromatography-coupled MS. I don't think I've ever seen a dedicated instrument that does only that.
