I dont think eg the Ukrainians will have to pay for the tokens...but they will be kind of rationed to them, so that they dont use more gas than they need.
Any better ways of getting cooking ability to eg millions of Ukrainian bomb shelter dwellers much appreciated?
EDIT: I think this particular forum (Electronics), is completely unsuitable/unsafe for discussing safety gas stuff like this.
Thanks, if your "pure mechanical" idea is possible, then yes, ...but i have doubts its possible like that...and it needs electronics circuitry. AYK, Gas engineer forums wont know about electronics.
A safe/quality gas engineering source, should be able to mention/specify any electronic parts/systems (even if they can't design it at a component level), at a high block level, if strictly safe/necessary. But I suspect electronics is undesirable and rather tricky to make safe. Especially with a latching (no further electric power needed), capable unit.
I.e. safe solutions, seem to always be continuously electrically powered (or self powered, e.g. via thermocoupling to the gas pilot/flame?). Presumably, as something which needs to be continuously powered to energise it (keep the gas flowing), will tend to STOP the gas flow, when power is lost, and/or other fault conditions. Which could be part of its safety design considerations.
There are other possible safety issues, with such equipment, in bomb shelters. Such as Carbon Monoxide gas buildup (highly poisonous), in a relatively confined space. Fire hazards in a relatively confined space, which could be difficult to exit, in an emergency.
Also risk of explosions, if the gas canister gets caught up in an external fire and/or is bomb damaged.
I.e. If you think where you are, might get bombed. You don't want to be sitting near a pile of Propane (or whatever) gas cylinders. Which could turn a minor bomb hit, into a much bigger/worse fire/explosion.
Maybe, better solutions. Would be to cook the food beforehand, elsewhere and then self-tin/can/bottle it (ideally following food safety rules). Then consume that food (which could also include supermarket tins). Cold, if necessary.
Is it possible to have an above ground, small petrol/diesel generator (very risky to have in the bomb shelter, itself. Because of the risk of Carbon Monoxide poisoning, in confined spaces). Then run a 'mains' cable down into the bomb shelter?
Would probably need lower power rating cooking appliances (assuming a small generator). But slow cookers, are something like 60watts, and rather small microwaves, can be fairly low (not sure without checking, but perhaps 400 watts).
There are mini-cooking devices for cars, which operate at 12 volts. Maybe those could be powered by a heavy-duty lead acid battery. You can then make a cup of boiling water, suitable for making instant soups, coffee, hot-chocolate etc. Nice, if that is the only hot food you can get, in the middle of winter.
My later solutions, are NOT 100% brillient (food wise), especially compared to 'normal' eating circumstances. But we are talking about a (hopefully) very, very rare indeed war (emergency) situation. 'Beggars can't be choosers'.
Actually, why not fill some thermos's with boiling water (BEFORE) the bombing air-raid warning. Then take those to the bomb shelter, and use the very hot water, to make warmer/hot soups/coffee, hot instant mash (potatoes), etc.
E.g. Use a machine, which keeps itself full of boiling water all the time (Hot Water Urn, plugged in, in a non-bomb-shelter kitchen). Then if and when an air-raid occurs, fill the thermos's with (near) boiling water. To improvise some kind of hot meal preparations/capabilities. Without any further need for gas/electricity.
