As requested by mk, tests were performed at 0.00a, 0.50a, 1.00a, 1.50a, 2.00a and 2.32a loads with the 20Mhz filter.
X10/Spring/20MHz filter applied
All of the following screenshots were taken with the x10 probe ground spring connected to GND of C1 and the probe pin spanned to the input of R9. A header pin was soldered to GND of C1, for convenience of connecting the probe spring.
Contact was maintained with hand pressure, only. The hand pressure could/was manipulated to obtain two types of results.
A) While the scope was in the Run Mode, hand pressure was manipulated, until the wave naturally settled into a recognizable form. It was then captured with the Stop Function. This connection resulted in a greater amplitude of the wave form than B, following. See TL and TS pngs.
B) The pin was connected without manipulation (just naturally placing the probe pin on the input of R9). The wave form was not recognizable, until captured with the Stop Function. This resulted in a lower amplitude of the wave form. See NTL and NTS pngs.
(Which is the proper means of testing?)
File Coding
x_xx = Amperage being sunk
TL = Hand manipulation A, above. Zoomed in.
TS = Hand manipulation A, above. Zoomed out.
NTL = No hand manipulation B, above. Zoomed in.
NTS = No hand manipulation B, above. Zoomed out.
SDS00021-24 = 2.00a and 2.32a loads, but they got out of order; order unknown.
The Stop Function was utilized. The Run Function shows much more noise, of course.
Conclusion: A 50KHz recurring ring/oscillation, of varying amplitude, is evident across all load values. What should I try, as a cure?
0.00a Load
No Hand Manipulation
Zoomed in.
Zoomed out.
