Author Topic: Electronic load PCB manufacture  (Read 2582 times)
Offline jpk42Topic starter
« on: September 18, 2016, 06:38:26 am »
Hi all,
I am designing a cased up ~300W electronic load for home use. All analog. I've designed the two PCBs for the unit and are looking at places to get them built. PCB GOGO seems like a reasonable choice, with a quote at $133 for both PCBs as a panel, shipping to NZ included. Any problems with them or can I get it done cheaper elsewhere? I can either panelize the PCBs with a V groove between them or send them off separately.
Specifications for the PCBs are:
Main board:
310x150
1.6mm
2 layer
2oz copper
min feature size 0.2mm
min hole 0.3mm
FET board:
250x59
1.6mm
2 layer
2oz copper
min hole 0.3mm
Thanks.
Online wraper
  • Country: lv
Re: Electronic load PCB manufacture
« Reply #1 on: September 18, 2016, 06:59:10 am »
Usually ordering separate PCBs is cheaper than ordering different designs in a single panel.
« Reply #2 on: September 18, 2016, 07:15:15 am »
I plugged the numbers into PCB GOGO separately and got $72 for the FET board and $110 for the main board, so more than the combination in a panel. That was with separate shipping however. Can I combine shipping?
Offline Siwastaja
« Reply #3 on: September 18, 2016, 08:07:54 am »
Use pcbshopper.com. I have had no problems whatsoever with the cheapest Chinese providers, even though I have had some special requirements, such as a lot of fairly accurate routing. They even ship quickly.
Online wraper
  • Country: lv
« Reply #4 on: September 18, 2016, 08:22:44 am »
