Hello all, I am trying to design a way to cut the ignition for a short period based on an input to an arduino. Everything works except for the fact that I can only supply a 5v "on" to the base of the transistor, resulting in the output being 5v too, not the desired 12v. Can anyone suggest a solution. It needs to be fast, so a relay maybe too slow. Any help appreciated
