Author Topic: Datasheet and/or specs for Reed Relay FRS12549  (Read 111 times)
Offline onesystemTopic starter
« on: June 14, 2024, 06:44:42 pm »
Not sure if this is the right section of the forum to ask this question on, but I am trying to get datasheet and/or specs for reed relay FRS12549.
On Cynergy3 website there is a spec listing for reed relays FRS series 12000, but not specifically 12549, which as I understand is a variation of series 12000. When I reached out to Cynergy3, their front-end tech support requested info from someone else who knows, but that someone else told both of us that the datasheet is not available due to FRS12549 being a military controlled product...
So how do I find out? What could be so classified about a reed relay that I may not know about it?
