Those brands of capacitors would probably be fine for use with low frequency stuff, like on the input and output of a linear regulator, or for some RC circuit, maybe some Arduino stuff, smoothing out some fan.. stuff like that... but I wouldn't use them in high switching frequency circuits... they'd probably be ok for prototyping in a pinch, but not for something you'd actually use or sell.. wouldn't use them for example when making a step-down or step-up dc-dc converter, led drivers, or when repairing a LCD monitor or some other power supply.
On electrolytic capacitors, I prefer Nichicon, United Chemi-Con, Rubycon, Panasonic, Elna ... Samxon and Teapo are not bad, not in the same league but above the "OK brands" in my opinion. Wurth electronic apparently makes good capacitors but I never used them.
Some other OK brands would be Aishi, Elite, Samwha, even Jamicon is used a lot in some devices...
There's some brands of polymer capacitors which are OK, like X-Con (if my memory is correct they're the Samxon solid/polymer capacitor division), Kemet makes a lot of solid/polymer capacitors as well and depending on how well stocked that part is they can be quite cheap if bought in volume (as in at least 25-50 pcs)
There's less popular brands like Kemet and Vishay and Epcos , they're just less popular in stuff I deal with (mass produced electronics like motherboards, monitors, switching power supplies).. maybe they're good in some applications or for some niches but I don't have experience with them
