I agree with IanB. Use mains rated cabling-it is rugged,& readily available.
75 volts isn't a lot,but nobody ever got sued for over-insulating wiring!
If your gig is out in the middle of a paddock somewhere,what kind of wiring do the audio & lighting guys use?
OB crews drag mains power all over the place with out problems,so you need to make the stuff as rugged as the gear they use.
VK6ZGO
P.S.I think the Ego-rizer guys guys use open mesh covers because they are using incandescents & have to get rid of a lot of heat.
With LEDs you can probably use glass or clear plastic (probably mechanically safer) under the metal grating & totally isolate the LEDs & wiring inside the boxes.
