Connecting power supplies in series is not a good idea.
Sometimes it can be done, but only if the sources were designed to support series connection. A laptop power supply is not designed to work like that. It can work or it can start a fire, you will never know.
Connecting series power supplies is not the same as connecting series batteries.
Apart from the Y capacitor, a lot of very ugly things can happen at startup. If one power source starts faster while the load is connected, then the other power source will see a reverse polarity at its output. Some power sources can cope with this, some other might be destroyed. Same if one power source over-current protection is triggered while the other one is not.
