Author Topic: Eagle question  (Read 1230 times)
Offline FloopyTopic starter
  • I'm going to need another oscilloscope to fix that
Eagle question
« on: February 23, 2018, 05:40:55 am »
Please understand me, I'm starting at this and I'm probably making so much mistakes that you are cringing on the other side of the screen.  :scared:
Anyway.
I'm currently learning to use EagleCAD and I've been designing what ever and wherever.
I'm currently making a boards that takes the pinout of a 9 pin miniature vacuum tube and distributes it to 9 terminals.
I wanted to put a Ground pin on the grounding plane, but I can't seem to figure out how to do so?
Can someone guide me and fix my mistakes hopefully.
Thanks
Re: Eagle question
« Reply #1 on: February 23, 2018, 05:42:40 am »
I'll upload a picture of the full board later.
Offline ArdWar
  • Country: sc
Re: Eagle question
« Reply #2 on: February 23, 2018, 06:19:24 am »
You already named the ground net in the schematics as GND right? (should be, as they're connected to GND supply symbol)
Then, You need to rename your ground pour/rectangle/polygon in the board editor with the same name (GND)
Use the Name tool.
Click one of the edge of your pour/rectangle/polygon, and rename it.
The pour might not automatically updated, use the Rastnest button to force update.
« Last Edit: February 23, 2018, 06:21:40 am by ArdWar »
Online westfw
Re: Eagle question
« Reply #3 on: February 23, 2018, 08:17:09 am »
If I'm adding a bunch (usually) of GND vias, I find it more convenient to:
  • use the text command window to enter via 'gnd' command, which names the vias as they're inserted...
  • or (once you have the first properly named via), use the copy command to make new copies to plunk down. (don't group a copy a set of GND vias, or it will rename them to "GND1")
Offline ArdWar
  • Country: sc
Re: Eagle question
« Reply #4 on: February 23, 2018, 08:25:51 am »
From the looks of it. It looks like the pad is properly connected (in schematics) but the pour itself is still default named.
Yeah, that'll cover the other possibility too,  I guess...
Re: Eagle question
« Reply #5 on: February 24, 2018, 02:59:04 am »
Thank you so much. I realize now that I probably should have posted this in "Beginner" section.
That seemed to be my problem.
I'm wondering if a "measure" tool exist?
It probably doesn't, but it sure would be nice to measure the size of something.
Re: Eagle question
« Reply #6 on: February 24, 2018, 03:03:33 am »
I think I'm done with everything. Any suggestions?
I know it's quit simple, but I'm just trying things out.
Online westfw
Re: Eagle question
« Reply #7 on: February 24, 2018, 11:00:09 am »
Tube are high voltage, right?  Do something to increase the clearance between the ground plane and the traces, either in the drc , or via "class", or "change isolate" on the polygon.
There are a couple ways to measure.  Use "mark" and the status bar will show the distance from the mark as well as absolute coordinates.  And there's a measurement tool.  Or what I usually do is draw a line on some innocuous layer, and the use "info" to see how long it is.
Re: Eagle question
« Reply #8 on: February 24, 2018, 10:12:15 pm »
Thanks will do.
The tubes I use don't go past the 200VDC range.
Online jpanhalt
Re: Eagle question
« Reply #9 on: February 24, 2018, 10:23:02 pm »
You might also want to use standard spacing for your pin headers.   Using the 3-pin or 4-pin (for ground) versions will ensure that, regardless of whether you use 0.100" or 0.156" spacing.  Many single-pin female connectors are not very durable.
« Last Edit: February 24, 2018, 10:24:52 pm by jpanhalt »
