While researching for my
cat location project, I stumbled upon commercial avalanche beacons and trackers, you know, those devices which can be used to locate avalanche victims under snow on the slopes. Apparently there are older analog and newer digital versions, using the 457kHz band. To my surprise, these devices, even old analog ones, are quite expensive and I also have not been able to come up with a simple diagram for how to do just a transmitting beacon (I'd be ok with buying a commercial tracker unit, but the transmitter would have to be as simple and as small as possible).
The beacon appears to transmit for about 200ms once a second but does anyone have an idea how the signal looks like, what's modulated or whether a carrier frequency is all that's needed? A 457kHz xtal seems impossible to find, so would a Colpitts oscillator (or similar) be drift-stable enough to stay within the +/- 100Hz?
