Author Topic: project: tracking generator synchronisation device  (Read 601 times)
Offline kirill_kaTopic starter
  • Country: ru
« on: July 24, 2019, 10:17:32 am »
The basic idea is to use the RFExplorer signal generator as a tracking generator for HP8561E.
Although my current implementation is built around the devices I possess, the idea can be extended for other spectrum analysers and/or signal generators. I plan to gradually release the implementation details for the case someone would find it interesting or even want to reuse my approach.
Block diagram
|RFE Generator    |        | Synchronisation |       | HP 8561E       |
|                 |        | Thing           |       |                |
|                 |        |                 |       |85620 module|   |
|                 |        |        SPI Slave|-------|GPIO/SBIT   |   |
|                 |        |            GATE |-------|GATE (not used) |
|             USB |--------| USB Host    SWP |-------|AUX Sweep out   |
|                 |    ----| 5V power    FAV |-------|Sweep out/FAV   |
|           RF OUT|-------- [DUT] -------------------|INPUT           |
                    Optional
                    5V power
                    supply
  • Country: ru
Re: project: tracking generator synchronisation device
« Reply #1 on: July 24, 2019, 10:23:44 am »
Tracking generator control/alignment UI
All the configuration is done through the custom menu on the HP8561E.
This adds some convenience by not requiring a PC. Also there's some fun in programming 8561E in it's archaic language.
The main "user keys" menu.
Sweep alignment menu. Also shows the generator swept across 6GHz.
Native tracking generator menu & normalised trace.
« Last Edit: July 24, 2019, 01:59:16 pm by kirill_ka »
  • Country: ru
« Reply #2 on: July 24, 2019, 10:24:20 am »
Hardware
The hardware is built round the ATMega 348P microcontroller and the MAX3421E USB host controller. For now I'm using a couple of slightly modified of-the-shelf boards. The MAX3421E board is an Arduino shield, but I'm not using it as a shield. That's because the SPI slave interface (which is normally connected to the MAX3421E) is needed to communicate with the 85620 module. An easier way could be to use some Linux-based board, but I suspect I wouldn't be able to get precise timing from Linux. Also I want to be able to power it from the 85620 which only provides 150mA @5V.
The whole thing is fitted into the shell of a dead LiPo charger.
« Last Edit: July 26, 2019, 07:17:50 pm by kirill_ka »
