Author Topic: help with daves power supply  (Read 1879 times)
Offline mj21Topic starter
« on: August 22, 2013, 01:02:20 pm »
i decided to build daves power supply he was working on many months back. lol. i build only the PS bit with out all the digital control. now everything works ok i can set the voltage to anything and the current up to 1.5amps and even more,instead of LT3080 i have build a voltage regulator based on (jung-regulator-2000). it works perfectly with out any oscillation.
but when i set the current to anything below 900ma i can draw up to 900ma from the power supply. so say i set the current to 200ma and i check with a volt meter the current pot reads 200mv, when the current draw reaches 200ma the CC led comes on and the voltage of the regulator drops to 100mv but if i try to draw more i can up to 900ma, after 900 no mater how much current i set my dummy load to i can not get more.
now i have tested this with my regulator i build or with lm317. same thing.
can some one please help.
« Last Edit: August 22, 2013, 02:10:38 pm by mj21 »
Re: help with daves power supply
« Reply #1 on: August 22, 2013, 01:08:34 pm »
ops looking at the picture i can see i have made mistake on the transistor and the pot for voltage. this is error in my drawing only. the circuit is all OK. i have checked everything like 10 times
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: August 22, 2013, 01:25:31 pm »
Lm334 directly on the output of the l 317 ? 10k in series with the input ?
Something is seriously wrong with this schematic ....
« Reply #3 on: August 22, 2013, 02:11:17 pm »
sorry it was late when i draw the circuit, but i have changed it now to the right one.
tnx
