Hello,
I'm more on the embedded dev rather than pcb design, so sorry, my question may sounds dumb.
I'm working on a board with dual rail supply (-15 0 +15 V).
On single rail supply I use a P-Mosfet reverse voltage protection circuit like the on you can find attached.
Not sure how to use this on the dual rail supply, I'm talking about the negative side. Can someone point me in the right direction?
Thanks!
